Ford Explorer problem
12 years 10 months before #36746 by manual-mecanica
problem with Ford Explorer published by Manual-Mecanica
How, I have a problem with a 1994 American Ford Explorer is heated too much when there is a traffic or in very prolonged increases, it no longer has thermostat someone has some solution. thank you
12 years 10 months before #36748 by manual-mecanica
Manual-Mecanica Response on the problem with Ford Explorer
Czech that the radiator is not covered and verifies whether the thermogutillator or electro -fan works correctly has the face of being nothing else.
12 years 10 months before #36782 by manual-mecanica
hello.
It would be good that you will tell us that condition is the water, if it has a different coloration or oily consistency, because if it is not the above it can be the butt packing, or simple air in the circuit.
luck
