Advice I pass water to automatic transmission
12 years 10 months before #36838 by manual-mecanica
Advice I pass water Ala automatic transmission published by manual-mecanica
I present the following problem, I spent water Ala Automatic Transmission of my American Explorer:( 2000 I came back then I put a 5 -liter carafe of quaker oil and I walk it and the changes do well but my doubt is without those 5 liters was enough and that the bayonet does not have but I clarify less of those 5 liters when the empty also checked the oil again and it looks no longer chocolate like when it had the water but rose Or that it is the most recommended, I am urgently urged tomorrow.: S
12 years 10 months before - 12 years 10 months before #36850 by manual-mecanica
Friend, I'm afraid you will have to stop the vehicle when this happens is because the accuser of the damage of damage, this goes inside the radiator, otherwise you will have to install another on the outside.
Latest edition: 12 years 10 months before by .
12 years 10 months before #36851 by manual-mecanica
Friend, I fear that you will have to stop the vehicle when this happens is because the oil cooler of the damage transmission, this goes inside the radiator, otherwise you will have to install another one by beast.
12 years 10 months before #36867 by manual-mecanica
What happens is that the transmission still brings water that is why the pink oil is seen, so that it is a little cleaner, it will be necessary to drain the turbine if it brings cap and if it does not bring you would have to remove the turbine and send it wash it because right now you
12 years 10 months before #36892 by manual-mecanica
Hi Martin What you devised Acer to remove all the turbine transmission fluid is to disconnect the 2 hoses of the cooler and turn on the car about 5 seconds to 10 seconds so that the turbines generates pressure and draw all the oil inside this does not damage the velusities pasta since they do not funeate if you do not put it in d hope
