Ford Ecosport "Spark plug problem"
12 years 10 months before #37120 by manual-mecanica
Ford Ecosport "Spark plug problem" published by Manual-Mecanica
Hello people!
I have a 105000km Ford Ecosport with problems when starting and fails to accelerate. The fault by accelerating is a cable in poor condition that jumped spark to the ground. I put new spark plugs on Platinum and failed worse, I put the old spark plugs again with 0.80mm of light between electrodes and say that it is perfect.
I ask: Something similar to Ecosport 2.0 has happened?
I appreciate any info about these engines
12 years 10 months before #37122 by manual-mecanica
Manual-Mecanica Response on the Ford Ecosport topic "Spark plug problem"
The truth is not that effect with the echo but can the platinum tip to 0.080mm and try, the cables are well?
12 years 9 months before #37258 by manual-mecanica
X Manual The light of Bujia is 1.15mm
to the new ones I gave the o.80mm that you recommended and walked Lujito. thank you
12 years 9 months before #37362 by manual-mecanica
Hello for me are the spark plug cables that I do not enter correctly and the spark of escapes the other way greetings
