Pulsation in injectors
12 years 10 months before #37226 by manual-mecanica
Injector pulsation published by Manual-Mecanica
HELLO EVERYONE. I am just coming, and I have asked for help.
I have a big problem with my Mistyque Ford 95 car which does not receive pulsation in the injectors and already check sensors, gas pump, computer, injectors, fuses and I have no longer I could desperate me if there is someone who can help me I will thank you enough.
THANK YOU.
12 years 10 months before #37234 by manual-mecanica
Manual-Mecanica response on the pulsation theme in injectors
I don't know if that model occupies CKP or CMP -CKP sensors
: crankshaft position sensor.
-CMP: Camshaft sensor.
Check these sensors when you have no pulse in the injectors may be due mainly to the CKP sensor.
To try what you can do is get the CKP and then give contact a skewer through the sensor's tip and you must listen to the click of the injectors.
12 years 9 months before #37363 by manual-mecanica
Hello if you have a spark in the spark plugs and do not press in the injections, it is possible that the immobilizer is blocked or have a failure in any component of the Ecu or switchboard (if you have a spark in the spark plug).
12 years 9 months before #37364 by manual-mecanica
Hey Pana, Good morning. If there is neither pulse nor pulse in the injectors nor current in the coils, which may be happening.
Apart there is no CKP fault codico,
12 years 9 months before #37366 by manual-mecanica
Surely the rpm signal is not arriving in the ECU does not know the point of the engine and it is as if you are not wearing greetings
