Problem with a great Cherokee 2000
12 years 9 months before - 12 years 9 months before #37286 by manual-mecanica
Problem with a great Cherokee 2000 published by Manual-Mecanica
The problem is the following to reach 1500 RPM The Motor fails, it seems that it is drowning or accelerating the fault, the engine is recent
Latest edition: 12 years 9 months before by .
12 years 9 months before #37292 by manual-mecanica
Manual-Mecanica Answer on the problem with a great Cherokee 2000
First take out a spark plug and fix if the rich or poor mixture is, then fix if it pulls black smoke by the exhaust. Also look if the distribution draft is fine, from there deduucis and you would have to check all the sensors that influence food system and measure them with an oscilloscope and a tester with the values ​​they have to have.
RPM sensor
MAF
sensor
Map
Sensor
Air
temperature
sensor and
butterfly body acutuator
12 years 9 months before #37307 by manual-mecanica
The other thing that could have happened to you is that they were put on a starter and the Ecu were left crazy, that is, but it does anything
12 years 9 months before #37334 by manual-mecanica
I agree with Blinihos the theme of spark plugs will guide you a lot along with the distribution and by adding something, check the escape, it is not that it is obstructed
