Helpatization Xsara Picaso
12 years 9 months before #37320 by manual-mecanica
CLIMATIZACION XSARA PICASO published by Manual-Mecanica
Hi, I need help with the air conditioning of the picaso, the air does not work either hot or cold or aa saveis what could it be?
12 years 9 months before #37329 by manual-mecanica
Manual-Mecanica Response on the subject CLIMATIZATION XSARA PICASO
Well many people say that neither the air nor the heating when in reality what happens is that the inner fan does not go and having no air movement there is nothing. Can this be your case?
I have changed several fans.
12 years 9 months before #37332 by manual-mecanica
Review the internal fan fuse first, the problem is there, then check the fan, it may need maintenance and finally the resistance could be bad, which if it is electronics it may be burned.
12 years 9 months before #37396 by manual-mecanica
That car you have, it has a multiplexed network that is a high information exchange technology between the vehicle calculators, in that vehicle
