Problem with Kia
12 years 9 months before #37462 by manual-mecanica
Manual-Mecanica Answer on the problem with Kia
Those cars are going the flow and the motor step by step, although there was also a campaign to supply the injector ramp, which I do not think it is there the problem, anyway it would be convenient to check the engine installation, it carries two connectors attached to the motor block just above the gearbox that usually give problems too. I hope you solve the problem.
