Problem with Kia
12 years 9 months before #37325 by manual-mecanica
KIA problem posted by Manual-Mecanica
Hello friends, it turns out that I have a problem with a kia river of the year 2002 16 gasoline valves it turns Electronic, I don't know what else to do it please if you can help me, I thank you for a lot thanks
12 years 9 months before #37327 by manual-mecanica
Manual-Mecanica Answer on the problem with Kia
If the fuel pressure is maintained in 2.5 bar, there can be said that the pump is fine ... You should also check if there is a signal cut for the injectors or for the ignition coil.
12 years 9 months before #37335 by manual-mecanica
If you know when you heat up and say that it has little spark it is logical Result of moment I leave this you will say how I have gone
