Ford Ka 1.3 fault
12 years 9 months before #37353 by manual-mecanica
Ford Ka 1.3 fault published by Manual-Mecanica
It seems to be the flow of the flow if you have the Rocam engine, it is common to pass when it is disconnected, I do not know why it passes, on the occasion it has been to see that a fuse is based on when it is disconnected or forgets to connect a ground cable that goes to the negative terminal of the battery is thin non -thick and cuts in occasions, also on the occasion it is necessary to configure the computer because the valve With that type of engine, party, currier, ka, etc.
12 years 9 months before #37354 by manual-mecanica
Manual-Mecanica response on the subject Ford Ka 1.3
You know what the boy told me that he brought it to me before taking out the lid stayed a little when he accelerated it, but now that happens if you take out the card is not good but it goes, when you connect it it stops or regulates and if you accelerate it short and not accelerate ..
12 years 9 months before #37355 by manual-mecanica
You know what the boy told me that he brought it to me before taking out the lid he stayed a little when he accelerated it, but now that happens if you take out his card as soon as he is, when he connects it, he does not regulate it and if you accelerate it, it cuts it and does not accelerate ..
12 years 9 months before #37356 by manual-mecanica
You know that the boy told me that he brought it to me before taking out the lid he stayed a little when he accelerated it, but now that happens if you take out the card is not good but it goes, when you connect it it does not regulate and if you accelerate it short and do not accelerate .. 1.3 endures and
