Atos Problems 1.1 2009
12 years 9 months before #37421 by manual-mecanica
Atos Problems 1.1 2009 published by Manual-Mecanica
Good morning, I have a problem with an atos1.1 2009, here there is a video for you to see what it does:
It happens that this vehicle changed the rings, metals and packaging, everything was closed, it was placed in time, but when you want to start it, the video happens, and the crankshaft deposition sensor changed, there is current and gasoline.
I hope someone can guide me that Deale can be escaping, thank you very much.
12 years 9 months before #37437 by manual-mecanica
Manual-Mecanica Response on the subject problems with atos 1.1 2009
It seems to be out of time, the camshaft pulley had only one position or has more than one, because it could also happen if it has hydraulic tachies that have not loaded them before Padrelor, because it sounds for the escape.
12 years 9 months before #37438 by manual-mecanica
Because the engine starts but it is not maintained or accelerated by what is seen, and listens, but it starts so that it is not a lack of component measuring comprehensive to see if the taquies are working or to ensure you of the comprehensive.
12 years 9 months before #37445 by manual-mecanica
The ignition order is well placed 1342 O1324 can vary.
12 years 9 months before #37448 by manual-mecanica
From what I see this vehicle was detained some times and may have obstruction problems in the fuel system, check the pump that has its required pressure and for anything, the injectors are dirty. According to its behavior that engine is without fuel pressure. Another thing is scanner to see what tells you
luck.
