ignition problems
12 years 9 months before #37431 by manual-mecanica
ignition problems published by Manual-Mecanica
I have the problem in a luminous of 99 when I am going to turn it on, it goes on white when you want to already put a push Button but nothing will thank you for a help.
12 years 9 months before #37440 by manual-mecanica
Manual-Mecanica Response on the subject ignition problems
There is a bit of information friend, the starter engine is activated or not? Do you want to start but spark or fuel is missing? Or when the start does not work, it is successful or not? Give us a little more of info to how much the battery and things fall.
