Fan 206
12 years 9 months before #37481 by manual-mecanica
206 fan published by Manual-Mecanica
Good afternoon, my problem is as follows:
I have a Peugeot 206 XR 1.4 of gasoline from 2001 and what happens is that when the car starts the electro cooling fan is constantly underway.
It can be. Greetings to all
12 years 9 months before #37483 by manual-mecanica
Manual-Mecanica Response on the fan theme 206
Go on your board as the engine temperature is, it can be the problem of the Sendor or wiring.
If you notice that the engine is half high in RPM on idle, the safest thing is the refrigerant sensor or a wiring problem ..
Check it well.
He had a similar problem with an atos, which was accelerated and the electro turns on when starting, led him to the mechanic and changed many things.
Then they brought it to me and disassemble the branch and found a cut cable.
I welded it and solved all the problems; The electro was stopped, and the idle was normalized.
luck
12 years 9 months before #37490 by manual-mecanica
It is true what Guillermo says but I look at because the 206 is activated by the electro when any of its sensors fails, if you have the light of the check on scanus it is not always by sensor or by temperature issue but by the emergency system of the ECU
12 years 9 months before #37494 by manual-mecanica
The thing is rare because the car was very heated and the electro jumped over the 90º boiled the water and went out the plug. The thermostat changed and the electro began to work well at 90º and stopped without problem. But he gave me the A/A Roiz of that, the electro stays at 2nd speed. The car also has Airbag faults.
How can I try the resistance that leads to the electro that makes the 2nd speed out.
All the best
12 years 9 months before #37496 by manual-mecanica
That resistance is seramics only put the tester in continuity and see if it is cut
