My Corsa's electro -ventilator does not start
12 years 9 months before #37484 by manual-mecanica
The electro-ventilator of my Corsa published by Manual-Mecanica
Hello .. If I tell you that the electro of my corsa wind 1.6 mod 00 does not start .. I connect it directly and if it works, I would believe that it is the bulb, but I do not know where it is located, I get tired of looking for it ... Someone could tell me DOND is (if it is in image better) or some ideas of that it can be, since I read me early more than 100! Thank you very much :)
12 years 9 months before #37486 by manual-mecanica
Manual-Mecanica response on the subject does not start the electro-ventilator of my Corsa
hello.
I tell you that what happens is that this car does not bring electro -ventilator bulb. It is fucked by the engine water temperature sensor which is mounted on the butt on the gearbox
perhaps that evil is electrically disconnect the electro -ventilator should work, if it does not work you have a problem in the wiring or the electro -ventilator relay, test and tell us.
12 years 9 months before #37495 by manual-mecanica
I think the problem is the relay, which would be the most normal.
12 years 9 months before - 12 years 9 months before #37497 by manual-mecanica
You can check if the radiator has a temperature sensor, in some models this sensor is in charge of operating the motorcycler, since the water temperature is cooled by the motorcyclector, if it has this sensor you can try it by putting it in hot water, there must be electrical continuity being hot, there is above 90 ° C I think, the sensor located in the cylinder head Contribute, I hope it serves you !!
Latest edition: 12 years 9 months before by .
12 years 9 months before #37506 by manual-mecanica
Victor Aguirre wrote: Hello.
Thank you friend, it served me a lot, that's ... I already solved it ... it was the temperature sensor, thank you all
