Fiorino 1.5ie Test Compression
12 years 9 months before #37485 by manual-mecanica
Fiorino 1.5IE Compression test published by Manual-Mecanica
How are you.
I need to do a compression test in a Fiat Fiorino 1.5ie monopunto 1993. But I don't have the compression values ​​to check.
Will anyone have the values?
12 years 9 months before #37489 by manual-mecanica
Manual-Mecanica Answer on the Fiorino 1.5IE Test Compression
hello.
With values ​​between or over 140 psi it is normal.
12 years 9 months before #37491 by manual-mecanica
Thanks Victor Aguirre for your answer. I came to another question regarding the Magneti Marelli ignition system with the Digiplex module apparently cannot be made on the distributor and setting lamp, since this would be handled by the digiplex? I moved the distributor for both sides and no difference.
12 years 9 months before #37492 by manual-mecanica
Up to 120 is good yet, if the compression comes out very low, I recommend you perform a simple test made oil in the combustion camera and measures the compression again if it rises notoriously then it is a rings problem if it does not do it is a problem of valves, but be careful because that model uses chachas and non -normal regulators, then the solution is between changing valves and regular valves or only regular valve valves.
12 years 9 months before #37493 by manual-mecanica
Indeed, it carries chauchas, when measuring slacks there was a lot of difference. As the chauchas were not found to change, it was decided to send to rectify and settle valves. When assembling and playing with the chauchas, the slack was reached again and they were agreed to Autodata. But when assembling the engine feels out of force. And that's why I want to check the compression.
