problems with my Chevrolet Monza
12 years 9 months before #37562 by manual-mecanica
Problems with my Chevrolet Monza published by Manual-Mecanica
Hello friends, I tell you, I have a chevrolet monza year 96 monopunto and the problem that makes it unstable, when it is accelerated, it does not respond to how it tends to suck and it costs the motor start, I have to let the accelerator step in depth so that it starts
12 years 9 months before #37619 by manual-mecanica
Manual-Mecanica Answer on the subject problems with my Chevrolet Monza
Hello Robrtox,
that fault can be several things
. The eccancial air filter, naphta.etc proba with this and tell me byby
12 years 9 months before #37643 by manual-mecanica
In request and manual exchange I uploaded the "Chevy - Monza 2003" file
12 years 9 months before #37646 by manual-mecanica
They could be several things, MAP sensor, fuel pump, ignition coil, some defective spark plug or even worn camshaft. Start by checking the simplest, removes the spark plugs and check them that it is not wet, if there is any wet or carbonized removes the taping lid, it has touched me in the monza that some cam of the tree wears out and does not work a piston.
12 years 9 months before #37674 by manual-mecanica
Fixed Friend Sindud is the temperature sensor
