Daewoo Racer automatic box
12 years 9 months before #37566 by manual-mecanica
Daewoo Racer Automatic Box Published by Manual-Mecanica
Greetings to all here.
That it may be that it is happening, the box is a Hydra-Matic, all the marches enter it, but you have to accelerate in excess to move the car. I want to measure oil pressure, but I don't have a value or contrast range.
12 years 9 months before #37803 by manual-mecanica
Manual-Mecanica Automatic Automatic Daewoo Racer
Recently, I had a problem with the box of a citroen, which happened to him, the diagnosis I gave him was the stator of the converter was bad, to be more specific the unidirectional set.
Make it to open the converter, change the stator, send and balance and solve the problem.
In your case I do not know if it will be the same but any information that you have about the pressures, I get it as soon as.
Greetings
12 years 8 months before #37833 by manual-mecanica
Thank you for your answer. Taking the Daewoo Sky manual, downloaded from this same page. And it is exactly the same AT box in my case HSC model. The pressures come out. I attach the image. Well the symptom of the box is skating of the box. You have some reference where they repair boxes.
12 years 8 months before #37836 by manual-mecanica
Where I know they could see them is in Allison in Santiago, but I do not know their phone number.
But later or tomorrow I will give you some information, and how to try the torque converter, now I do not have much time ...
to all this ... did you review the oil level to your box ?????
That could also be ...
greetings
12 years 8 months before #37839 by manual-mecanica
Well the oil level revizes it with hot and operational engine. And it is on the level, and it is also evident that the oil is bad because of its coffee color. I hope with peace how to try the converter.
