It controls the set -up of the distribution well, controls the pocition of the ignition cables, see that it is not the same as that of other V8 engines, is V8 right? Rover has a different from the distributor to other V8, look at the spark in the cylinder one when he makes the expocion face I hope my help is help you are you in Spain?
Hello again are you in Spain? I have Facebook and Messenger controls the little lingden cables that Rover works differently than others V8 is true? that the spark jumps in the cylinder number one when it is in the expansion face that injudes naphtha the injectors
