Mustang 99-04
12 years 9 months before #37707 by manual-mecanica
Mustang 99-04 Published by Manual-Mecanica
I have a problem with my Mustang 1999 V6 3.8 standard. The engine oil with the radiator water is being in force, I would like to know how I can grind that without having to fix the cabsas like everyone, I design me somewhat tight of money and I would like to know if I can throw away the cracking that Seed and iso that was being in moderate, thank you.
12 years 8 months before #38019 by manual-mecanica
Manual-Mecanica response on the subject Mustang 99-04
A question, the mixture of water and oil, as you realize, that is, the water enters the engine or oil enters the cooling system (radiator)
in case the oil entered the radiator, it is not necessary to change or rectify heads.
12 years 8 months before #38020 by manual-mecanica
To make a more precise diagnosis you have to remove the head, because in no way can you know, it may be that it is only packing, it can be some cylinder head, but recommending that if you do not handle yourself much on the subject you take it to a service, because this brings great problems, but in the best case it is only the packaging.
Luck
12 years 8 months before #38144 by manual-mecanica
It is an oil change and I did not find any water, only oil on the radiator, I put a sealant and stop that funeate opens a state well or that another opsion would give me. This is the photo of the sealant that I put
12 years 8 months before #38152 by manual-mecanica
Look at something very similar, in my Mustang 2001, 8 cyl, and the piece was the oil cooler, this piece is located below the oil filter, inside the piece I suffered correctness and the oil passed to the cooling system (radiator) changes the piece and ready, the car is 100. You will have to purge your radiator several times, to eliminate the oil residue that remains in the radiator. The piece is simple to remove you will have to tell your mechanic to check it, normally everyone is inclined to the heads of the heads and head rectification, there is no need. I hope it serves you, greetings.
