Putting with Hyundai Santamo lamp
12 years 9 months before #37818 by manual-mecanica
Manual-Mecanica Response on the topic tuning with Hyundai Santamo lamp
Another query, to tune or check it, do I need to disconnect something? So that the ECU does not correct me every time that I move a crankshaft position sensor? thank you
12 years 9 months before - 12 years 9 months before #37820 by manual-mecanica
The IAC does not adjust, the ECU does automatically.
If you disconnect it clearly go down or upload the RPM.
As dicts that lower the rpm when you turn on the lights, check the battery status if it is from the correct amperage of the vehicle, and check the load of the alternator, that also influences that.
For the other, what moves is not the figger of the crankshaft, what moves is the distributor. It is not a sensor.
Luck
Latest edition: 12 years 9 months before by .
12 years 9 months before #37821 by manual-mecanica
Well look at the battery is new is 3 months old, the amperage is 60 AMP as the car manual says. I suspect a bit of the talves wiring, the masses are not very well or some cable already fixes several defective cables. In other car I had, I always adjust the set -up by moving the distributor as you comment, but in this car I do not have a distributor, I have this sensor that is solidarity to one of the axes of the camshaft. I attach the photo. Total consumption in current medium with an amperometric clamp of continuous and medium about 43 AMP (with lights and compressor walking). The alternator carries 14.5 volt, I could not measure what a current delivers, but I will check it on the weekend.
12 years 9 months before #37823 by manual-mecanica
According to I see you can move you must release the nut of the ears that marks you, they are usually 2 but mark you 1 to get guies.
You loose it and move it.
There you tell me if it turns out.
12 years 9 months before #37830 by manual-mecanica
Guillermo you are right but this model regulates release by water temperature is ultra malaso hahaha but that advance that you show a lot accelerates the engine and puts the starter if you want to accelerate a little and only a little to climb the revolutions The throttle piola has a plaquita with a Chinese eye that can be run for this end and also in the admission body there is an air passage screw that serves to lower and lower the revolutions.
