High temperature Gran Cheroke Laredo 1996 V8 5200
12 years 8 months before #37825 by manual-mecanica
My truck rises the temperature of 100 I have changed water pump
12 years 8 months before #37828 by manual-mecanica
Manual-Mecanica Response on the topic High Temperature Gran Cheroke Laredo 1996 V8 5200
Maybe it is a problem of head packaging ..
12 years 8 months before #37832 by manual-mecanica
They have a temperature bulb or Command Ecu, if it commands by ECU changes the temperature sensor if it does not work to be that it is not a problem packing problem
12 years 8 months before #37835 by manual-mecanica
I controlled radiator (which does not obstruct tubes) which decreases heat exchange layer. I am going to do the same with other customs
