- Thanks received: 1
06-19-2025 Hits: 771 Technology
Testing, we changed the injectors of place and changed the fault to another cylinder, the injector to laboratory was sent and the problem was solved. It probably happened because my wife and daughter frequently use gasoline with sulfur. I asked them to avoid it.Carlo A wrote: Good point, according to "the agency" is not common but I will verify it and notify them how it was solved!
