Zetec Rocam engine, this engine has many temperature problems and devoted to its structure is complete of aluminum, the theme of warm is quite complicated, I recommend you run a scanner so that you come out of doubt if the light is turned on will be more economical to make the scanner than to try to guess. Now because I tell you about the temperature, look at the exhaust if the sound it makes is poarejo or cut if a cylinder does not check the spark plugs that you took out and see if its color is orange is passing water, if you do not lower your water level it can be a coil problem and nothing else, as that vehicle uses chain and does not strain it is difficult and almost impossible that the distribution runs
