The lighter does not work !!!
12 years 8 months before - 12 years 8 months before #37965 by manual-mecanica
The lighter does not work !!! Posted by manual-mecanica
Hello very good !!
My problem is that the car lighter does not work for me and if I wanted to know if someone tells me how to extract it to change it.
If not if they prefer you can send me a workshop manual and I look for it myself but if that would need the manual.
And a question does the lighter have a fuse? but? Is it to look at it if that, and where would it be located?
My car is an Opel Astra G 1.7 dt of 2002 or so.
Thank you very much in advance !!
Latest edition: 12 years 8 months before by .
12 years 8 months before - 12 years 8 months before #37984 by manual-mecanica
Manual-mecanica response on the subject does not work the lighter !!!
I guess you mean the lighter ...
and if it carries fuse, I think it goes in the internal fuselera in the habitaculus, you take out the lid and check in this where the fuse is located.
If you were burned, you just change it.
12 years 8 months before #37989 by manual-mecanica
Thank you so much!!
I have already found the fuse and made it molten. And that is already discovered a last question where could I buy it?
If I will not go to a scrapping.
Thanks again !!
12 years 8 months before #37991 by manual-mecanica
In any part where they sell automotive spare parts, it is very common to have.
You just have to look at the same value as burned, that is defined by color.
But carrying the sample (molten fuse), they will give you an identical one.
luck
12 years 8 months before #38011 by manual-mecanica
thank you so much!!
see if they are lucky and encounter.
If I take a sample yes.
Thanks again !!
