How to realize that the starting solenoid is
12 years 8 months before #37987 by manual-mecanica
how to realize that the starter solenoid published by Manual-Mecanica
How to realize that the burnt starter solenoid
I have a Hyundai Elantra
Model: 1998
Motor: 1.8
NAFTA
12 years 8 months before #37994 by manual-mecanica
Manual-Mecanica response on the subject how to realize that the starting solenoid is
Ovarily if you have it in your hands, I would have to be with a very strong smell that would be burned and bad now the question will be because it does not start could be the sheet continuity of cables to short coals I hope it helps you
12 years 8 months before #37999 by manual-mecanica
or testing its resistance if it is burned, apart from the smell, it will have a resistance or an infinite resistance.
As Huipi says it can be the problem of wiredodes of the sheet.
But the question ...
the starter engine turns you when turning with the key ????
12 years 8 months before #38005 by manual-mecanica
Thanks for your fast answers.
I tell you that the engine revolved but with very little strength,
and when connecting the direct battery cable it began to turn, and this should not do it.
12 years 8 months before #38010 by manual-mecanica
That is lack of land nothing more, check cables and give more earth, if the solenoid is burned the engine turns but the vendix does not come out.
