- Thanks received: 1
06-19-2025 Hits: 822 Technology
Guillermo_felipe wrote: In any case, no others are changing rings, but that must be made prior diagnosis.
That if you change will have more compression.
The question is that if the pistons collided with the valves ???
And if so, they must first check the status of the pistons, because they could be resentful, and that can work a problem of greater magnitude in the engine.
But if your mechanic says that it is fine and confused 100% in the diagnosis, you should not worry.
But you should see that of the pistons if they were resentful.
Luck
