Failure in Grand Blazer 1997 ... trembles a lot ..
12 years 8 months before #38051 by manual-mecanica
I have a newly bought truck, Grand Blazer 1997, 4x4, 8 Vortec cylinder engine. It worked very well, until a water stick fell and I had to go through a lagoon where the water reached half of the door. I managed to pass ... but the month began a fault as if it were electric, I thought that a spark plugs had fractured due to the temperature change. And indeed there was a game, I bought the new platinum, but the fault followed, changed the spark plug wires and follow the fault, well clean the MAF sensor, position of the crankshaft, the pressure of the admission chamber, the PCV valve, change the air filter. and gasoline. But continuous failure ... has no strength, it is as if starting at two speed. When I put Park, or stop or put it in drive with the brake placed the car trembles a lot. As if combustion were not complete or there were no cylinders without working. Could it be water in the gas tank, or damage to the box ?????
The last thing I did was to shine it and I threw a p0102 code error, which is the MAF sensor. Delete the code with the computer or scanner and improve a bit ... but today he presented the fault of the trembling, and has not turned on the bulb or check light the engine .. will they be the dirty injectors ???
12 years 8 months before #38053 by manual-mecanica
Manual-Mecanica response on the subject fails in Grand Blazer 1997 ... it trembles a lot ..
test by reviewing the ignition coil (s) may be that any is not sending current to the spark plugs or otherwise the injectors of some have no signal or this covered luck
12 years 8 months before #38054 by manual-mecanica
The escape is clean? Check that ..
the spark plugs you put are the recommended, with the specified opening?
And what code did you give you now?
12 years 8 months before #38069 by manual-mecanica
If friend are the specification spark plugs, and it has not given me more code
but the trembling in a continuous minimum ...
12 years 8 months before #38070 by manual-mecanica
Ok ... I'm going to check the coil, but why does it not tremble and the intonation is matched? Or it must be that I don't feel it. I will do what you recommend to see ...
