Fiat point 1.2 8V, year 2000
12 years 8 months before #38062 by manual-mecanica
Fiat Punto 1.2 8V, year 2000 published by Manual-Mecanica
Good morning everyone, I tell you my problem to see if someone can help me.
This morning when I have started the car, the motor light has been crew.
The car has been circulating correctly, without any apparent symptom, the only thing I have detected is that the engine temperature has "late" more than normal to rise at its normal temperature.
Can it be something temporary, or can it be first symptoms of switchboard failure, or what else ???
Well, first of all thanks to everything
12 years 8 months before #38065 by manual-mecanica
Manual-Mecanica response on the subject Fiat Punto 1.2 8V, year 2000
Check Engine's light should turn on for a moment, and when starting it must go out.
If this does not, it may be that it has an electrical problem with some sensor or actuator.
It would not be bad if you would send a scan to know what it has (in the event that the light remains on).
Greetings
