Citroen Picasso lights
12 years 8 months before #38160 by manual-mecanica
Citroen Picasso lights posted by Manual-Mecanica
You can repair the Picasso Lights Command of 2003, they get alone and the command has no automatic position. Thank you
12 years 8 months before #38283 by manual-mecanica
Manual-Mecanica Answer on the subject Citroen Picasso Lights
But after they are turned on, can the connections reviewed?
12 years 8 months before #38309 by manual-mecanica
Look if not before that it is most likely that the telecoming has been damaged and you have to replace it only that can solve it Good Look
12 years 8 months before #38327 by manual-mecanica
Telecomandos are plastic do not have much arrangement it is best to change them but they are expensive, much more can be done can be tried but it does not work on many occasions.
