Renault Clio Motor 1.6 Year 97
12 years 8 months before #38172 by manual-mecanica
Renault Clio Motor 1.6 Year 97 Published by Manual-Mecanica
Hello everyone, my query is as follows, I have a year 97 and the temperature pilot sometimes turns on as the oil pilot, I have reviewed and no problem with a temperature or oil pressure, why does this happen ???
12 years 8 months before #38174 by manual-mecanica
Manual-Mecanica Response On the Renault Clio Motor 1.6 year 97
Hello friend
in most cases the problem is solved by changing the temperature sensor, which being the engine running when the temperature sensor fails the two pilots are lit, I mean the temperature and oil, and when it would see it it is of oil lights this last one only
greetings
12 years 8 months before #38175 by manual-mecanica
Hello friend
in most cases the problem is solved by changing the temperature sensor, which being the engine running when the temperature sensor fails the two pilots are lit, I mean the temperature and oil, and when the fault is made of oil lights this last one only
greetings
