Peugeot 504 diesel pick -up clutch
12 years 8 months before #38176 by manual-mecanica
Peugeot 504 Diesel Pick Up clutch published by Manual-Mecanica
Hello everyone, my name is Roberto, I live in Buenos Aires and I registered on this site because it is very interesting if you want to learn.
I have a consultation, it turns out that I bought a few days ago a Peugeot 504 Diesel Pick Up of 87, has a lot to restore but I am satisfied until today. One of the works it requires is to do the clutch, the cable is supplemented to the maximum with pieces of small diameter pipe ... The fact is that when I put the changes it is turned off except that the pedal thoroughly presses and keeps it accelerated although it usually goes out the same. The question is what is the most appropriate step by step to replace disc and plaque, (incidentally I rectify the motor steering wheel) so that it does not complicate too much in the rearmed, I have done this laburo in other vehicles but do not resemble the one I have now. Thank you very much !!!
12 years 8 months before #38254 by manual-mecanica
Manual-Mecanica response on the pick-up clutch theme Peugeot 504 Diesel
Hello friend, so you comment on the clutch no longer gives, to repair it you have to disassemble the differential to lower the box, with all the problems that it entails, it is easier to disassemble the engine and incidentally eliminate oil losses if any, do not put a replace Go, greetings. :)
12 years 8 months before #38276 by manual-mecanica
In trucks it is easy to disconnect the differential, you take your start and take out the cash bolts, disconnect the gear lever and you are already, the rectified wheel is determined by its own state you will see when you lower the clutch, remember to remove the cash oil first, but I do not think it is your problem, I that you check the set -up of your vehicle, I tube the same problem with a partner
12 years 7 months before #39002 by manual-mecanica
Hello again! Well, I tell you that as long as the ignition drum began to fail and reviewing below, we discovered with a friend that a connector made false contact every time putting a change. The selector hit him because he was hanging and produced the current cut until he put it in the dead to turn on the engine and thus indefinitely !! It was not a clutch problem and I saved 1200 spare parts mangoes. I have not had much time to put a hand because I am with a lot of work, and this "discovery" was C ... because I needed to transport my tools from a laburo and suddenly behaved like when you run out of battery and there we begin to check a bit lightly. Anyway, thanks anyway for the advice they gave me because I value the goodwill and because perhaps later I serve the orientation that they gave me. Thank you very much again !!! :)
