Fast oil consultation
12 years 8 months before #38258 by manual-mecanica
Quick consultation oil posted by manual-mecanica
good night!
A quick question, I have changed the oil today, and when filling it, they have told me to the maximum so that I spent 100 ml or less. In an omega 2000 dt of the year 99. It is very little that is the past of the needle indicator I do not know if it will have any kind of margin to the real or something similar. Anyway, if you can already advise me, it is very little the past and the best until it is adjusted with the new filter and that drinks it. But I want your advice. thank you!
12 years 8 months before #38260 by manual-mecanica
Manual-Mecanica Response On the Rapid Oil Consultation
With 100 ml more, it should not fail you, when it passes over the 450 ml there you have to take it out, because the oil begins to beat and it loses properties.
12 years 8 months before #38261 by manual-mecanica
It is very little, look more exactly on the rod can see 2 millimeters above the maximum, and there is doubt but we go if there is no problem up to 450 ml I stay calmer. Can another thing see anything abnormal that could see? Rare smoke type for a few days until I threw it or something similar. thank you
12 years 8 months before #38263 by manual-mecanica
In fact you should not worry, the only smoke that can throw you if something bad with the oil is a blue smoke, which indicates that it is burning oil.
But when changing acite with filter, everything should be.
The same is recommended before putting the oil filter, filling this with oil, to make a more immediate suction.
greetings
12 years 8 months before #38264 by manual-mecanica
The car walking little this afternoon about 15 - 18 kms road about 2000 laps and not done anything weird or out of the usual. So reading your answers, I will let it be and settle the oil well this week and if I see that I will take it away, I would remove if not a little bad. Thanks for your small answers!
