Fiat Uno Fire 1.3 16V
12 years 8 months before #38300 by manual-mecanica
Fiat Uno Fire 1.3 16V published by Manual-Mecanica
Hello, they could help me, the scanner throws this fault code: P0110 (the admission air tempo sensor would be badly working) but the sensor is not in the filter, I would like to know where it is located.
12 years 8 months before #38315 by manual-mecanica
Manual-Mecanica Answer on the FIAT One Fire 1.3 16V
Hello, the fiat one Fire the air temperature sensor is located in the MAP sensor that has 4 positive cables 5 v another negative and both are one signal from the MAP and the other of the air temperature sensor means that the sensor has both functions.
12 years 8 months before #38367 by manual-mecanica
I share what Maurog says.
Causes
The potential causes of DTC P0110 include:
IAT Sensor displaced outside the air flow
IAT Sensor Badly
short -circuit to ground or open in the IAT signal circuit
in the Earth circuit for IAT
bad connection of IAT (terminals were removed, broken locks connectors, etc.)
Mal PCM
