I do not set a Water Water Filter Dysel-Battery Large-Premister Spark plugs: When I give contact, only light oil after the ignition, thank you very much forgiveness, it is an L200 of 2001 DC Thailand or Japon, don't you know?
Hello, I would tell you that you start for the fuses, if these are fine, dismantle the board and check if it comes positive to the battery witness lamp, check the lamp, lamp holder, and if this is not a solution check the board connector, otherwise if you know how to interpret electrical schemes, verify those circuits.
