1.3 SOHC Hyundai Accent Motor
12 years 8 months before #38401 by manual-mecanica
Manual-Mecanica Answer on the 1.3 SOHC Hyundai Accent Motor
Ok I will wait for the 500km to have the oil that I put 15W/40 since I did cleaning the injectors weighing that I could be passing further gasoline to the cylinders and also adjust the time to see how it goes if it turns black and then empies it to consume does not see smoke out of the escape but consume it does not have boats anywhere
12 years 8 months before #38402 by manual-mecanica
Thanks for your help I will be informing you how I am going with the oil. I think there is a problem with the rings or engine temperature although I do not see that lift temperature on the clock does not pass a room if the problem continues will have to lower the engine to check
12 years 7 months before #38965 by manual-mecanica
Good evening the problem continues to reach 560 ky again put the black oil and consume it in a week I put a liter I will lower the engine again to check the rings any advice is agreed thanks
