distribution runs
12 years 8 months before #38361 by manual-mecanica
distribution corresponds by manual-mecanica
Hello friends, I wanted to ask them if anyone knows why you can leave the distribution coorrhea, since I place it and when it starts to turn it begins to leave and the strap of what should be its position with respect to the center of the gear is started. thank you so much
12 years 8 months before #38363 by manual-mecanica
Manual-Mecanica Response on the topic of distribution
What vehicle,
do you turn it with the crankshaft pulley on or removed?
Any axis with slacks? For example water pump?
12 years 8 months before #38372 by manual-mecanica
In general, this problem is due to a desalination of the pulleys, either by game of one of the components, or by poor condition of them, but eye the straps do not rotate in the center always do it right on the shore in general.
12 years 8 months before #38387 by manual-mecanica
Hello Juan, you may have some axis of a folded roller.
Check all the rollers first (have you changed them?).
If for any circumstance it is beaten or this has been bent can do what is described.
You must also be more concrete (tell us the model) to be able to make a mental review of it and be able to say something else.
SL2
