Smoke output by escape
12 years 7 months before #38484 by manual-mecanica
Smoke output for the escape published by Manual-Mecanica
I have a Mercedes 230E (W124) of 1987 automatic to which I have a lot of love, because it is in my possession since 1999 when I went to look for him to Germany.
Well, the problem is that I start it and while taking temperature the engine is coming out through the exhaust some water motorcycles impregnated with some oil, (but little thing) when the engine is reaching 85 ° C or 90 ° C launches a large amount of white smoke with a certain smell of burned oil, but in no case the smoke is blue or black.
So I have loved I would not mind spending a little money in him.
Thus, a affectionate greeting to all foreros.
Eduardo.
PD took him to the Mercedes house they did not tell me the diagnosis, which if they told me that I would cost me more the repair than in what was valued the car. ! Of course they cure in health when a car arrives with some years.
12 years 7 months before #38485 by manual-mecanica
Manual-Mecanica response on the topic output of smoke
The white smoke with black droplets is moisture if later it continues to make more white smoke, the first thing you have to do is make a route circulating with a short and high march of revolutions so that the silent burns all the interior that is impregnated and stops making smoke that usually happens if short routes are made and the escape does not heat up so that it burns everything that is impregnated.
If smoke does not stop out or you will have to disassemble the cylinder head and check the hoops
12 years 7 months before #38488 by manual-mecanica
If the white smoke is generally a button or packaging of it since the water is passed to combustion, in the worst case this item or trisada the sneakers luck
12 years 7 months before #38544 by manual-mecanica
To give you a successful response, more information
1- It is gasiline or diesel your engine
2- It is spending oil between each change
3- When you remove the tabon of the radiator the water pulls bubbles
4- When the engine is working it rises more than normal the temperature
greetings
12 years 7 months before #38754 by manual-mecanica
Good day friend only scores how the white smoke fails through the excape tube, I want to tell you that this situation is almost normal in the mercedezz, the combustion of the environment is almost normal and when the combustion is perfect it is normal that this tube condenses water does not consider it as failure, greetings
