BMW320D 150CV 2004
12 years 7 months before #38579 by manual-mecanica
BMW320D 150CV 2004 published by Manual-Mecanica
Hello very good my question is the following, my BMW only manages to start the return diesel tube wherever I want to strangle it, do you know why ??? thanks in advance partners
12 years 7 months before #38661 by manual-mecanica
Manual-Mecanica Response on the topic BMW320D 150CV 2004
You may have a leak in the high pressure circuit, easy to be an injector, you should check the return flow of them.
12 years 7 months before #38923 by manual-mecanica
Compa, it is almost clear that the problem is in the return valve, I am stuck open and fails to accumulate pressure for the injectors.
12 years 7 months before #38937 by manual-mecanica
Ok compi but how is or where this return valve if you can take a photo or some data to locate it, greetings and thanks
