Consult Toyota Yaris 2008
12 years 7 months before #38614 by manual-mecanica
Consult Toyota Yaris 2008 published by Manual-Mecanica
Good morning everyone,
I am new here and I have a consultation with respect to the Toyota Yaris Sedan 2008.
The helon I have noticed that it is a bit hard, I have searched for the hydraulic oil deposit but I can't find it.
Any of you can tell me where these vehicles bring it or do you not use ..?
Thank you very much for your answers.
12 years 7 months before #38640 by manual-mecanica
Manual-Mecanica Answer on the topic Toyota Yaris 2008
Mmmm nose if it is from or the full, if it is electronic or hydraulic condemire, it depends on what country is not all the same there is variety if they are Mexican, Japanese, Brazilian. Give us the chassis and motor characteristics to help you better, but anyway looks for the hydraulic pump that must be in the auxiliary strap and follow the entrance to the deposit that is the easy way.
12 years 7 months before #38781 by manual-mecanica
If it is 2008, it is most likely that it is electronic and non -hydraulic direction checks if after lighting the engine a light is turned on on the red dash
12 years 7 months before #38785 by manual-mecanica
Hello in Toyota, not only the yaris depending on the year of manufacturing no longer use hydrahulic address, they now use a service (electric motor) electronically controlled by the ECU of the self -taking reading or command from the helm.
Att.jorge Diaz
12 years 7 months before #38822 by manual-mecanica
Thank you very much for your answers, it is indeed electronic address.
