Change of the SEAT MAR DIRECT CREAM KIT
12 years 7 months before #38619 by manual-mecanica
CHANGE OF THE DIRECT CRED CREAM KIT PUBLISHED BY MANUAL-MECANICA
I need someone to explain how to proceed to change the Kid (I don't know if that's what it is called) of Seat Marbella's direction zipper, a gratitude from the arrangeman, Juan
12 years 7 months before #38646 by manual-mecanica
Manual-Mecanica response on the topic of the direct marble zipper kit
By kit do you mean the interior seals of the zipper of the direction?, if so, you will have to disarm a lot of direction themers, direction axials, release the fixation of the zipper with respect to the chassis and then relete it with respect to the direction column eye with this part that you must mark so that the direction is not crooked or counterbalanced.
12 years 7 months before #38648 by manual-mecanica
Ok, thank you very much, precisely what I am looking for is not to put the leg and do it well, what I intend is to change the cap and the overalls, if it would be kind and you will expand a little I would appreciate it very much, thank you and an affectionate greeting.
12 years 7 months before #38654 by manual-mecanica
What are the caps? The powders are not to disassemble a lot but the bushes is my question as to guide you
12 years 7 months before #38708 by manual-mecanica
It is the cap that goes in the right bar, I think, that is metalcaucho or something. That bar is like lazy or that you move it and not the notes fixed like the other. That must be under the overalls on that side.
