Black Smoke Daewoo Pointer
12 years 7 months before #38635 by manual-mecanica
Black Smoke Daewoo Pointer published by Manual-Mecanica
I have a Daewoo Pointer 97 1.5
The problem is that it throws smoke when I accelerate it. In idle he has no problem.
I change the oxygen sensor and the IAC valve, but the problem persists.
The video is not mine, but it is exactly the same problem I have.
I would appreciate your help ;)
12 years 7 months before #38645 by manual-mecanica
Manual-Mecanica Answer on the Black Smoke Daewoo Pointer
Check the water temperature sensor, and clean the air mass meter.
12 years 7 months before #38647 by manual-mecanica
Change the head valve stamps (button)
luck
12 years 7 months before #38652 by manual-mecanica
Because of the type of fault that is seen, it can be MAF or MAP sensor if you already checked them only the load air temperature or the motor temperature is left
