Ford Fusion does not start
12 years 7 months before #38687 by manual-mecanica
Ford Fusion does not start published by Manual-Mecanica
Good, I have a Ford Fusion, and I had the starter engine that sometimes did not work, I changed it x another one that I got in 1 scroll that if I worked because I bought it. At trying to start the car does nothing and a lucecita of the panel in shape gives a key flashes, they have told me that it will be the key that has been decoded but I have caused with the other and nothing. Call one that encodes keys at home and could not tell me that it will be something else. I don't know what can be ... any suggestion? Thank you
12 years 7 months before #38699 by manual-mecanica
Manual-Mecanica response Ford Fusion subject
Can it be the immobilisator or antirobo that is activated, turns on the rest of the lights or just that of the key?
12 years 7 months before #38707 by manual-mecanica
The other lights do, the light that flashes is not a key. It is a car with a lock. If the choche is without contact, it flashes slowly but how much I give the contact flashes fast and the car does nothing. Thank you
12 years 7 months before #38728 by manual-mecanica
mmmm short current does it have installed? The start is extended or not to reach the current?
12 years 7 months before #38746 by manual-mecanica
Corta current does not carry, and the start does nothing does not reach current. :(
