water on the driver's side.
12 years 7 months before #38688 by manual-mecanica
water on the driver's side. Posted by manual-mecanica
On some occasions when the car goes away some liquid on the ground under the pedals. (closer to the accelerator) I think it can be from the heating radiator but also persisted that refrigeration water is also consumed. My question is whether one thing can be related to each other? I mean that water that comes out of the heating area is the refrigeration water.
12 years 7 months before #38700 by manual-mecanica
Manual-mecanica response on the water theme on the floor of the driver side.
If, indeed it is the same water, the lack of refrigerant is on the ground is communicate that it passes, if you want to make sure your diagnosis you have a bridge between the hoses that enter the heating on the front by the front by means of a tube, it is what you can do while you decide whether or not to change the inner radiator.
12 years 7 months before #38747 by manual-mecanica
dq vehicle is ... ??
I had the same probation with a Peugeot206 and the problem was the Board of the tube that goes to heating. It was not sold alone in the house but the tube with the joint cost little, anyway you can find loose joints.
12 years 7 months before #38760 by manual-mecanica
Thank you, I'm going to try the bridge to see what happens. Then I tell you.
