How to remove the overdrive of my civic 2006
12 years 7 months before #38740 by manual-mecanica
How to remove the overdrive of my civic 2006 published by Manual-Mecanica
Hi Maigos Good morning.
I have an ex -automatic civic 2006 and the over Drive, or automatic pilot, how to unlock it? Thank you so much.;)
I also have problems on the brake pedal, when I tread it, the speed lever is unlocked, I must do it manually.
They help me for FA? Thank you very much.
12 years 7 months before #38918 by manual-mecanica
Manual-Mecanica response on the subject how to remove the overdrive of my Civic 2006
Good Leonardo, you are a little wrong. I explain you, Overdrive is not automatic pilot, that in any case is the Cruisse Control that sets the acceleration electronic for long trips and not having to keep your foot in the accelerator. The Overdrive would be the envelope or on direct march, and is used in automatic boxes to give a more march to the one that originally leads and thus takes better advantage of the rpms of the engine with respect to the speed with which it generates a better consumption. I explain? With respect to the fact that it does not release the park point with the brake I tell you that it carries a selenoid at the foot of the lever that is activated with the same hot line of the brake lights. You must take the time to disarm the small console at the foot of the lever to find the problem, unless you realize that you do not have brake lights with what could be the pedal switch or the fuse of the brake lights.
12 years 6 months before #39105 by manual-mecanica
Thank you very much for your help ... : Cheer:
12 years 6 months before #39147 by manual-mecanica
On one side of the lever on the console it has a groove there introduces your key is for emergency cases when the Czech parking is not disabled with the pedal and comments.
