My Cherokee 97 spends me in 100km half tank
12 years 7 months before #38793 by manual-mecanica
My Cherokee 97 spends me in 100km half tank published by manual-mecanica
I fill the tank and spend in 100km half a tank is already refined but I don't know why it consumes me so much gasoline I don't know if it is the oxygen sensor or something else
12 years 7 months before #38920 by manual-mecanica
Manual-Mecanica Answer on the subject My Cherokee 97 spends me in 100km half tank
Good compi, the only thing I can recommend to start is that you put it on self -diagnosis to know if any sensor is screwed. It is easy, with the key in the start drum, you give him ignition and take away three times, you leave it in ignition position but without starting it. The witness of Averias that is the light of Check Engine will begin to flash. The flickers, the first group of flickers indicate tens the second group indicates units. The dozens of the units are separated from a short pause. Each complete code of damages is separated by a long pause. Let's say (three flickers, short pause, two flickering, long pause) is equal to Averia code No. 32, after the long pause begins another different code or none in case of being the only one. Once the code is identified, you put it on Google for Jeep/Crysler and ready. Or in any case you possess it and I spend the detail to search.
