Subaru Legacy GT 2.5 problem
12 years 7 months before #38856 by manual-mecanica
Problem with Subaru Legacy GT 2.5 Published by Manual-Mecanica
Hello, I hope you can there with my problem I have a subaru legacy gt 2.5 a/t awd 2001, and problem is presented with pulls and loss of power in high and low as it will run out of benzine scanning and threw lost bencina flow, changed the original pump and spark plugs and the problem you perceived, to check fat
12 years 7 months before #38869 by manual-mecanica
Manual-Mecanica Response on the problem with Subaru Legacy GT 2.5
Hastegureate that there are no leaks or air inlets to the fuel system that happens to the Corsa, if it is good that the injectors are in good condition.
12 years 7 months before #38898 by manual-mecanica
You could look if it is a good gasoline and a cleaning of injectors would
