Problems with my neon
12 years 7 months before #38857 by manual-mecanica
Problems with my neon published by Manual-Mecanica
Good afternoon, I have a Neon 2.0L, Mod 1998. My vehicle changed the camshaft sensor league because oil summarizes. After this change to state with faults, by forcing the car in climbs, it is very slow, it does not let change of D to 2 and the reverse does not limp and you have to accelerate it to more than 3000 rpm, so that it enters. I don't know if you owe to the axis sensor or some other problem. I hope you can help me.
12 years 7 months before #38859 by manual-mecanica
Manual-Mecanica Answer on the subject problems with my neon
how are you !! Have you put the scanner to see the codes?
12 years 7 months before #38870 by manual-mecanica
Before making the repair the vehicle behaved well, was it soft?
12 years 7 months before #38888 by manual-mecanica
Hello, if connecting the scanner and shows no failures, I already have symptoms where the fault can be, there is a lack of hydraulic oil to the box and being low in oil I suppose that the lack of pressure does not enter the changes.
12 years 7 months before #38890 by manual-mecanica
Hello good day I suggest that you check the position of the new sensor with a re -use of the used must be outdated
position you can screw it that someone of marching miras
