Antiniebla lights in an Xsara Picasso
12 years 7 months before #38878 by manual-mecanica
Antiniebla lights in an Xsara Picasso published by Manual-Mecanica
Good morning. I have an Xsara Picasso in the workshop with an electrical problem, the rear fog lights are burning constantly, even with the contact removed, they remain tenuously, with a voltage of approximately 7 volts in each light, if I give to the anti -harb lights they are normally ignited, in addition the population lights do not work, nor in front or behind. I suspect the BSI, but I am not sure, and a BSI is expensive in addition to unrecoverable once installed in the vehicle.
Does anyone know anything about this? I wouldn't want to roll it if I change the BSI and it is not.
12 years 7 months before #38879 by manual-mecanica
Manual-Mecanica response on the topic Antiniebla lights in an Xsara Picasso
Before doing anything, the lands and try to make new lands for the lights of Aras on occasion only that is needed.
12 years 7 months before #38887 by manual-mecanica
It is not the problem of the masses, that was the first thing I looked, anyway thanks for bothering you.
12 years 7 months before #38897 by manual-mecanica
You set the relay, you may be stuck.
12 years 7 months before #39011 by manual-mecanica
I advise you to check the connectors in the rear headlights themselves, which many times make a bad contact and produce what is called seeking current and when passing through the bulb lights it with little intensity. Look pin to Pin Each connector clean them well and with a small screwdriver they bend inward so that they make better contact.
