response
12 years 7 months before #38904 by manual-mecanica
Replacement published by Manual-Mecanica
Blessings to all those who participate in this forum, my apology if anyone knows about 4m41 montero diesel
12 years 7 months before #38921 by manual-mecanica
Manual-Mecanica Response on the topic responded
Good compa, I am watching in the self -body that your car has immobilizer, I ask ... the key with which you give the start is the original? It may be that if it is not it will not start or by chance. The only one that occurs to me if they give you the signs well is that you have a problem with the immobilizer. Sometimes the plastic that is behind the key itself is broken, and people boot it. This piece of plastic contains the transponder that sends the signal to the starter drum, if it is not attached to the key, the vehicle does not start.
