IMSTALLATION TACOMETRO PROBLEM
12 years 7 months before #38929 by manual-mecanica
Tacometro Imstalación Problem published by Manual-Mecanica
I install an rpm tacometro but I have problems with the signal because I connect it to the outlet of the coil but it marks half someone knows where I can connect it for a Hyundai Accent 97
12 years 7 months before #38930 by manual-mecanica
Manual-Mecanica Response on the subject Imstalacion Tacometro
Hello, the first thing you should check is the position of the cylinder selector that bring the tacometers, usually in the posterios, look at the number 4.
I hope this info serves you.
12 years 7 months before #38993 by manual-mecanica
L or connect to the coil and brand only half we also tried from the signal of the crankshaft position sensor but does not only reach 3 thousand but accelerating almost to the cut. If you know where you can get a real signal from the RPM for a Hyundai Accent 98 that is not from the computer 6 of the computer.
