Hello, how about someone can guide me, I have to fix the change box of a Seat Cordoba, it has a noise when putting the third as when we fail with the clutch as if the gears scrape with each other, then it is removed, they have told me that it could be synchronizers, and also another problem is that it sounds as it is impaired as if the order of ignition was bad, the motor discharge? I would like to know what could be working badly, I will also disassemble the box, but the problem of "decarburacion" I do not know what to do to isolate the problem. Could someone give me indications?
Thanks
GUSTOVO GUSTAVO
